Reply To: Beosound 9000 sledge touches the back of the CDs – The solution
#16261
pierre69
    • Lyon, France
    • Topics Started 2
    • Total Posts 5
    Thank you Matador,
    Yes, I will make a feedback in several weeks.
    There is one thing I have noticed when I opened the unit, is that the damper was moving freely around the rocker arm. Is it normal? Is it due to the wear? I don’t know. With the heat shrink over it , the damper is more tight on the rocker arm. That’s the only difference.
    Will the wear out faster ? I don’t know, time will tell.
    For the moment everything is fine.
