Reply To: Odd Playmaker issue
#16146
francoisvl
    • Topics Started 3
    • Total Posts 11
    So I purchased a powered network adaptor. The adaptor has full bar signal…..connected the playmaker via Ethernet cable. It works initially then a couple of hours later when the TV has been used it has the same problem. As soon as the TV is switched on I can’t connect anymore to the playmaker via Airplay. I can see the playmaker on Apple Music but it says cannot connect. If I turn the TV off the playmaker still doesn’t work, I have to reboot the playmaker each time.  I have tried to change the channel used on the Wifi router but it made no difference.
