January 25, 2023 at 9:42 pm
#15019
Thank you so much – obviously I have older manual of LC2, because I had only programming with BeoLink 1000. I’ll try to remove the top cover and I’ll see if this strip is missing. Do you have any picture how it should look like? I tried LC2 using 4W bulb (eco 🙂 Couldn’t find any bulb > 30W at home 🙂 )  – can it cause unresponsive touch sensitive surface ? Or this should work regardless of the bulb?
