January 23, 2023 at 3:02 pm
#14866
can you tell me where the “lower display connectors” are found? Do you mean in the lower board of the two, or is it found in another place than where the displays are mounted?
A better description of the location is on the bottom cover of the speaker. This cover is the access point to the crossovers. There is a round 8 (or 9?) pin connector on it. You will see the wire connections that I’m talking about if you remove the bottom plate.
On my Pentas, the wires are small and don’t have any strain relief. The other end of the cable (by the displays) has a better connection (crimped versus soldered)
Glitch
