January 20, 2023 at 9:09 pm
#14733
Mine works exactly as explained – yes I was thinking it would be good for a streaming/airplay source such as Airport Express. I think that the newer version is a bit easier to use because the control surface is a better shape and the ‘all off’ function has moved to the edge. Details here: https://www.beoworld.org/prod_details.asp?pid=734
I meant to add: With my LightManager Pro the long and short press of the LIGHT button on the A9 is a selectable input, hence I can decide how I wish the lights to respond, with different scenes for ‘Keyring Short’ and ‘Keyring Long’.
This reply was modified 2 weeks ago by
Guy.
