January 19, 2023 at 3:46 pm
#14651
The PC input worked fine using pins 2, 4, and 7 for Left, Right and Gnd respectively. I could select using ‘PC’ on Beo4 and it worked as a local source…
Hi Guy. Does it means it work the same way the 1611 converter but just limited to the PC input ? (meaning, remote control working to start the speaker, set volume and adjust sound parameters, all through the Link Speaker sensor only.)
…but as soon as I disconnected the ML it stopped working – so there is no simple BL Active standalone option.
Why would you disconnect ML since it’s the only way to drive a Link Speaker?
