January 19, 2023 at 3:16 pm
#14650
However, the way the Theatre and Room-Sense works is initially, when setting up my 5.2.2, (please note, I designate my system as x.2.y because of the BL90 “subs”), the system recognised it as 7.2. Therefore, with the Theatre, you have to designate the two new channels as height channels – almost like it calibrates like DTS-X?
This is because the automatic Speaker Role detection cannot “see” the height of a real loudspeaker.
Therefore if you DO have loudspeakers that are mounted high on the walls, or on the ceiling, you’ll have to assign “height” Speaker Roles to those outputs manually as an adjustment to the automatically-chosen roles.
