January 18, 2023 at 5:54 pm
#14591
First you should note that your phone is heavy relative to a record and this will negatively impact the WF test on most beograms due to their lightweight construction, floating suspension and low torque. To use that app you need to readjust the suspension so it’s free and level when the phone is centered over the spindle and that the belt is centered on the pulley and platter. You should also also make sure the motor pulley and platter edge are clean. Finally, unless you got the belt from a legitimate B&O parts site, I would suspect it.
