January 17, 2023 at 1:48 pm
#14483
@Madskp Yes those solution are the ones we try to avoid. They use the PL mode from service “Menu 0 4 GO” and the speaker is turned off as soon as you touch any key on the remote. Volume is set from the source and to me the more important: you lose the sound adjustments from the BL3500. It is clearly much better to have the 1611 solution. But when you have it, adding an extra source for casual needs with the PL path is something that comes free and can be useful.
What I take from thoose solutions is the pins used in the DIN connecter for respectivly MCL and PL , not the use case.
