I decided to get a little better organised and prepare a list of setups tested, and those still to test. They are numbered so that we can refer to them easily. I have uploaded as a pdf but am happy to upload as a word doc if you want to amend for your own use.
Great idea.
regarding test 8: the powersource doesnt has to be 5V. The specifications states >2.5V, so maybe a coincell battery or two AA will do for testing.
Regarding test 12: single components may not work because og the difference in Audio Link, And Audio Aux lin. Dont know which the DVD use though, so might be something working.
Regarding test 13: Take a look on the diagram of the BS1 in the servicemanual. Pin 7 is called dataOut, so might control a tape recorder. Pin 6 is called data in, so I guess its not two way communicationif it works at all. Actually pin 6 and 7 is stated as not connected in the specifications for the BS1. Therefore its only on the diagram its shown
