January 14, 2023 at 4:29 pm
#14219
What happens if you press Menu 0 3 Go while the 1611 is connected?
will one of the sound inputs from it be open? If not you might be good to go with that solution.
Another thought is the Power link connector on the Beolab 3500.
it should be able to be feed by pressing Menu Menu 0 4 Go according to this http://www.soundsheavenly.com/faq/using-beolab-3500-mk-2-sound-bar-speaker-dock/
But might not work when the Beolab 3500 is connected to ML. Might be Worth trying though.
another source https://www.reddit.com/r/BangandOlufsen/comments/rvr4f4/best_way_to_modernise_a_beolab_3500_soundbar_as/
indicates that the powerlink port. Could be activated with 5v. But again dont know if it would be possible while ML is connected
This reply was modified 2 weeks, 6 days ago by
Madskp.
