January 12, 2023 at 7:39 pm
#14110
Hello Michael,
I don’t remember who posted it, but someone recommended using just a little baby oil on a soft cloth for the brushed aluminum. I have found that works nicely and just give it a good wipe down with a dry cloth to remove any excess. Regarding the plastic lid, if you have scratches, depending on the severity you will have to use sandpaper or abrasive polishes to remove them. There are several posts in older forums on doing that and some Google searching can lead to others. One thing I have learned is find a product that is an abrasive rather than a wax, the one that are mostly wax just hides scratches. Polishes made for restoring plastic are a good place to start.
