January 11, 2023 at 9:52 pm
#14067
My understanding is this that if you have a bunch of Matter enabled devices at home, you will still one device that can act as a Matter hub. The difference in this world being you only need one hub device, not the current situation where some use cases / devices combinations require >1 hub.
Newer Apple TVs are the obvious example where many will already have a Matter enabled hub device at home already
