On MK2 that has only ML and a frustrating useless Powerlink socket, what would be the use of turning off Masterlink?
I think that in some setups (with Wireless 1) you are suppose to connect via the 8-pin plug. The Mk2 service manual mentions this, without calling it MCL. I will see if it is mentioned in the PCG.
EDIT: There is also this text, Google translated from one of RaMaBo’s posts in that earlier thread I mentioned:
The 8 pin DIN connector may also be an MCL connector if the BL3500 has been updated with a new software version! Then there is an MCL connection electrically, but technically a PowerLink connection for the software! The PL Connector will then not work properly! This can be recognized by the serial number of the BL3500: from SN.19343452 it is really a BeoLab 3500 MKII, before that an MKI with a physical MCL connection! Unfortunately, both sockets look identical.
Hence different behaviours for different software versions of Mk2.
This reply was modified 4 weeks, 1 day ago by
Guy.
