January 7, 2023 at 8:19 pm
#13805
Still investigating…
OneRemote sells a Radio Multi Receiver that connects to a Masterlink installation through a 1611 converter. But depending on the cable used to connect it to the converter, it seems it appears as audio source or video source. Cables are VSNUT and ASNUT. Cables being all the same price I wonder if it’s a marketing trick or if there simply something in the socket, like a resistor between the two datalink pins, that fools the converter.
Another lead: connecting it to an Audio Unit like Guy suggested, let him autoconfig and power it off. Then connect it to the Beolab 3500 but without letting him autoconfig, which would be something like powering the converter first and the Beolab after…
Will try this tomorrow and report.
