January 7, 2023 at 5:56 pm
#13795
It is worth experimenting with connecting your (MCL-era) BC2300 to the 1611, this just needs a 7 pin DIN from AUX to the 1611 (no PL connection is required).
If it’s in the same room, put the BC2300 in A.OPT 0 first to avoid double IR commands, and then see how the BL3500 behaves with various Option Settings.
The 1611 auto-configures to a video- or audio-master when power is applied, so maybe you can spoof the 1611 into reconfiguring and then disconnect your BC2300 and connect the other source? However, you are taking a risk by making/breaking connections whilst power is applied.
