January 7, 2023 at 12:36 pm
#13768
Had a look at the leaf spring contacts and they look clean, gave them a squirt of Deoxit non the less…..once dry I will re install the control panel and try it again….I do recall having issues in the past once the panel screws are tightened down, i think if they are not evenly tightened they flex the PCB causing erroneous signals…….
