January 6, 2023 at 9:11 pm
#13746
Hi KolfMaker,
Thats the one I would like, Yes.
I’ve still not seen one for sale around but I was told they’re quite expensive.
There is a wall stand for sale in local ads and it’s around 60€, that is more that I paid for the two 3500.
That’s when finding bargain B&O stuff dont helps you ! 🙂
BTW, stil no luck in fixing the powerlink input, but if the 3500 from your friend is an MCL model, you should try the 5V trick!
Regards.
