January 4, 2023 at 7:48 pm
#13652
Ah, I see. You want to use speakerlink rather than powerlink. Is that correct? I am not 100% sure but even in that case you need the four pin version. The two pin version likely can’t feed the display with data since it doesn’t carry the signal. Why not opt for powerlink? Cables are more readily available since speakerlink is slowly dying out. The connectors in your picture won’t do the job. Kai
This reply was modified 4 weeks ago by
Manbearpig.
