January 3, 2023 at 1:35 pm
#13567
Any chance this TV is not HDCP compatible?
No – even my old BV10-32 is HDCP compatible!
Have you tried the BluRay player with another TV? Could it be faulty? (EDIT: Just re-read that you had tried with a PC monitor – sorry!)
As a side note you have probably noticed that your replies are not formatted correctly. It’s a bit clunky, but use the tab above the message box that says ‘text’ rather than ‘visual’, and then make sure that your reply is on a line below the final ‘blockquote’ text. You can then click the ‘visual’ tab to make sure that it looks right.
This reply was modified 1 month ago by
Guy.
