January 2, 2023 at 8:13 pm
#13515
I just edited my above reply to be more specific.
The felt washers are oil reservoirs sitting around the bearings.
You will see when you take it apart. (Yours will have hardened or at least run dry).
It’s a special technical felt material meant specifically for this purpose.
The bearings pull oil from the reservoirs to replenish and compensate for what is being used.
