January 2, 2023 at 5:02 pm
#13491
Hi Roger,
It does get hot but not burning hot. Are you sure it runs smoothly (lubrication) and that you have the correct speed right away? Did you have to increase pitch adjustment to its end stop? Do you have the original belt?
