13 March 2022 at 13:09
#30202
Ok…..cleaned the drawing up to include the actual transformer wiring details and took some measurements…..these are all with the turntable running and under normal load conditions…everything works fine though the voltage regulator gets hot…put a heat sink on it which helps quite a bit.
