December 30, 2022 at 1:56 pm
#13290
I’m afraid that you’re still confusing things. There are two competing formats: Dolby and DTS. Each has lossy, lossless, and object-based versions. Object-based is more than just height channels. Some object-based soundtracks do not even use height channels. Discs often support some versions of both Dolby and DTS, but many offer lossless or object-based in only Dolby or DTS and not both. So we have to chose which soundtrack. B&O should just support both Dolby and DTS so that we’ll always be able to get the best soundtrack.
There is a huge difference in quality that you get between lossy and lossless. Why would you spend the money on BL90s and a Kaleidescape system if you’re not going to get the best sound from your system?
This reply was modified 1 month ago by
beojeff.
