December 28, 2022 at 12:55 pm
#13161
How do you manually add a speaker connected to the Receiver 1? Thanks
You cannot include the Receiver 1 in the speaker group when performing Room Sense or Room Sense will completely fail. After you create the listening position with Room Sense without the Receiver 1, you select the listening position, touch the three dots in the upper right corner, and then select Advanced settings. This will allow you to then select the Receiver 1 to include in the speaker group. However, you must manually input all values for the speaker — it isn’t automatically calculated by Room Sense. This feature was added in the latest version of the B&O app.
