December 23, 2022 at 11:14 pm
#13013
Does anyone know if it is possible to set a volume level when changing source? I know there is the default volume setting when you turn it on, but I would like to have different levels when I change to the various HDMI ports
Only way I know of to set different startup volume values, is to use the MyButtons as the source starter.
However, I also would like to be able to set an individual start up volume for each source (or even for each Listening Position).
When I get an overview of ‘my wishes’ for the Theatre, I’ll include this…..and will send it through the (beta) app to the support team.
You could do the same….the more the better.
