December 23, 2022 at 10:16 pm
#13010
- Ok, thank you. I will measure with the multimeter if there is Dc voltage on the speakers after switching on the beomaster. If so, it would be a regulation problem of the final stage of the amplification which should thus be verified and investigated. But probably the bump is normal as Chartz reported. Yes Chartz, I use the switch to disconnect the speakers :-).
