24 November 2022 at 13:19
#25137
That sounds promising. I will hang onto my Beoport for when I move house and set up an ML or NL system. I do like the ability to control my PC using Beo4 and I can see the value in listening to ML/NL sources from the computer room/study. I suppose one of the major advantages over BL Active (using PC input) is that you can ‘mix’, the computer sounds with the ML audio input, thus still getting PC sounds such as email alerts.
