November 23, 2022 at 10:02 am
#11616
Has anybody here managed so far, to add a pair of older Beolab speakers via Powerlink to the Theater?
I added a +10yr old BL3s without issue. I imagine that you may have a cable/adapter cable/channel switch issue? Is a coax connected to the BL5 to another digital source? Remember, coax carries the signal, powerlink the volume signal? Disconnect if you do and retest?
No coax connected to the BL5’s … just Powerlink and quite the same issue while trying to connect the BL90’s via Powerlink.
Dealer says, it is a known problem supposed to be solved with SW update.
Then again you managed to get your BL3’s connected with Powerlink. Have to talk to B&O, i guess.
