Reply To: New product launch – beosound theatre?
#11538
Beo911
  • Topics Started 0
  • Total Posts 28
… wireless has restricted/less resolution.
I might have missed something, but can’t you just connect the Beolap 90’s with powerlink to your Theatre? Or is it because you want optical or similar instead? 🙂
I can, but if i do so, the room compensation process via the BS Theatre can not be applied. I have to connect the BL90 in wireless mode (WISA) to have that feature working. It ‘s a software bug/failure.
And of course i wan’t to run the BL90’s wired via Powerlink to get the maximum sound quality out of them.
