Reply To: New product launch – beosound theatre?
#11526
allanminds
  • Topics Started 0
  • Total Posts 3
Hi
I have a problem with aux in, only one channel is playing. I’m using the original b&o supplied cable #6271374.
I’m using the same cable as before with my beosound core, but now just with the b&o mini jack to usb-c cable in to the theatre.
When I plug the minijack into a beoplay m3 and multirom it to the theatre, then both channels are playing.
I also got another minijack to usb-c adapter from my dealer, same problem.
Just tested after new software release, same problem.
Have anyone used the aux with the minijack to usb-c adapter?
Best regards
Allan
