Reply To: Beoport/Beoplayer
#11472
patcherley
GOLD Member
  • Hampshire
  • Topics Started 5
  • Total Posts 27
Guy,
My Beoport PC N.Radio worked fine on Windows 10 until the last update, about 2 weeks ago. Since then, though N.Music works and linked sources from my Eclipse also play, N.Radio does not play a station. Installed on an old Windows XP laptop and on  Windows xp virtual machine on Windows 10 it all works fine. So as you say a driver may need replacing or it is internal in the software using something that was unsupported and as now been replaced.
Paul
