Reply To: New product launch – beosound theatre?
#11423
Mr10Percent
  • Topics Started 2
  • Total Posts 155
Yes, overall it is very comfortable and I’m happy with the solution. It actually looks better live than the photo.
The box is slim-line at 26cm x 26cm x 110cm. This is just to fit the table stand. Some furniture solutions tend to be 40mm deep as a minimum and therefore take up more foot print.
The TV and VESA back (SMI) are right up against the wall. The table stand can be flipped between a wide and narrow foot – I guess this is to accommodate larger screens or those with electronic packs at the base and thus ensures good centre of gravity??
Two things put me off the motorised stand – 1st was obviously the price which I think is stupid, 2nd was the real estate and the positioning of the screen in the room which would be very forward.
