Reply To: New product launch – beosound theatre?
#11421
Millemissen
  • Topics Started 7
  • Total Posts 265
That is always the problem 🧐
You look and look for the right solution….and can’t find it.
Then you go for something temporary……..which stays so untill you again make a change in the setup 😲
That said – I hope that you/Mr10% find something better soon, because that solution in the picture certainly does not do the Theatre and the 90’s justice.
Question @Mr10% – you went for the table stand.
Is that made far or near (dependent on how the platter is turned)?
How far from the wall is the backside of the LG tv?
