Reply To: Beosystem 2500 powerlink failure
#11411
matador
  • Paris France
  • Topics Started 31
  • Total Posts 328
That’s weird! If you’ve been using the converter through a Powerlink wire and the converter cliks in/cliks out, it means the powerlink socket is correctly passing sound and power (right now I’m wondering if there is the same pin that triggers both devices beolab or converter…).
As for the headphone socket, I dont know if it’s a relay or just a switch built-in the jack socket. When I tried it just before posting, I didnt hear any relay appart from the loud ones from the beolabs just there.
