November 19, 2022 at 11:45 am
#11409
Hi, I’m not good at this but what comes to my mind: Do you have sound from the headphone socket? Did you deactivate the converter as mentioned above? Do the mute light light on or off accordingly, meaning could it be a stuck key on the keyboard? Could it be the headphone switch that is stuck?
Hi Matador,
Thanks for your reply.
Um no, I didn’t deactivate the converter. It was an MCL2P – I didn’t state that correctly in my original post sorry.
The mute button on the keyboard does activate the little green light as expected. Doesn’t appear to be stuck.
I’ve connected headphones and sound plays through them fine. I don’t hear a relay click when I plug them in though.
Perhaps a randomly failed headphone relay?
Julian
