Reply To: Beosystem 2500 powerlink failure
#11407
pepps
GOLD Member
  • Kent, UK
  • Topics Started 11
  • Total Posts 76
When you say that you ‘had it connected to a BL converter and was playing through some Beovox’, do you mean that you were using an ML/MCL converter as a Passive (amplifier) using its PL input, and were you connecting it to the BC2500 using the same PL Mk3 cable that you are trying to use with the Beolabs?
Hi Guy,
Thanks for your reply. I was using a Powerlink cable I bought from Steve at Soundsheavenly from one of the Powerlink sockets on the BC to a MCL2P and then on to the Beovox.
I’ve since tested the BL2500s with my BV6 using both a Mk3 Powerlink cable (works fine) and the original 5-pin Powerlink cables which came with the BL2500s (works fine).
Julian
