Reply To: Beosystem 2500 powerlink failure
#11405
Guy
  • Warwickshire, UK
  • Topics Started 10
  • Total Posts 386
When you say that you ‘had it connected to a BL converter and was playing through some Beovox’, do you mean that you were using an ML/MCL converter as a Passive (amplifier) using its PL input, and were you connecting it to the BC2500 using the same PL Mk3 cable that you are trying to use with the Beolabs?
