16 November 2022 at 19:41
#25432
I suspect you’re talking about a BeoSOUND 9000, multi CD player, right?
If so, I suggest you edit your post title and you may then have more answers.
Most likely the belt yes, google Beoparts, I’m quite sure they must have correct belts.
From memory you just have to remove the top parts and it’s not a big deal.
Hope this helps.
