Reply To: BeoGram 4000 tone arm problem…
#11247
hcraig244
SILVER Member
  • Topics Started 3
  • Total Posts 106
A very high percentage of problems experienced with these decks result from switches, either on the control panel or the transport slider. A switch out of position be it open or closed will play havoc with the boolean logic control gates, I have chased my tail for weeks trying to locate a problem that turned out to be nothing more than an intermittent sticking contact on a transport slider switch……an issue that had been identified as a possible cause by Dillen at the outset….however as it was intermittent when I tested the switch it worked fine…turned out that the silicone grease i had blobbed onto the plastic nipples (which I thought would help keep them free) was causing them to bind due to the viscosity……thorough cleaning and has worked fine since…….I’m rambling I know ;¬)
Craig
