Reply To: Beomaster 4000 – wicked pop when turning on
#11115
graydonslc
SILVER Member
  • Topics Started 3
  • Total Posts 6
My repair guy has called me with the same problem. The loud POP when first turned on. I have 2 Beomaster 4000 amps. When I got the 1st one going it did the pop thing. After running it for a while ( days ) It seems to have gone away. ( Just a small click sound on power up. ) On to the next one. It does the same thing after capacitor replacement( audio caps only ) . Have not tried to run it for an extended time. My repair guy had me order the complete set of tune up parts and capacitor kits from Beoparts. We will see if we get the same problem after a complete work over. I’ll keep you posted as to what we find. They both sound fantastic, but he said, pick one and it will sound even better after the overhaul.
Graydon
