Reply To: beogram 5500 turntable repair, gear disassembly?
#11065
Dillen
  • Topics Started 2
  • Total Posts 156
Soldering star capacitors have four leads. One center positive and three negative in the outer circle.
You can fit a general purpose capacitor with reasonable specs instead, just make sure to get the
polarity right and connect any negative pads that were previously connected by the original cap.
