Reply To: Which IR eye for the Beolink Passive?
#11063
matador
  • Paris France
  • Topics Started 31
  • Total Posts 331
Did you try Test Mode on the Passive?
Yes I just did and it worked. The Passive cliks in and the sensor react (blinks) to IR commands.
Tnak you Guy.
But are you saying It can not be turned up with a simple key on the remote and fed by power link? So long standalone Passive…. 🙁
