Reply To: old Beosound 1 Japan version change radio frequency?
#10867
Guy
  • Warwickshire, UK
  • Topics Started 10
  • Total Posts 393
I have a old Beosound 1 with Japan version; The radio frequency is like from 76 to 90; Can I change the radio frequency to the normal one like 87 to 108?
I have had a look at the manual and I don’t think it’s possible.
If you look at the ‘specification’ section, the Japan version gets a specific mention in the Tuner section, whish suggests to me that the actual tuner hardware is different: (none of the other country versions gets specific mention here)
japan
Edit:  Also if you look at the ‘Available Parts’ list, you will see that type 2584 has a different part number for the 01Module – the main PCB including radio:
tuner
  • This reply was modified 3 weeks, 6 days ago by Guy.
