Reply To: Beocord 7000 voltage issues
#10843
Die_Bogener
    Put a 12V 5W light bulb … or 2 of them inline … in the overload line. Replace the fuse with the lights.
    If you have a light, then there is a problem.
    I told you, that the motor has caps inside (!!!). Check it.
