Reply To: Beocord 7000 voltage issues
#10836
alf
  • Topics Started 14
  • Total Posts 86
Ok,
i am back on the BC7000 after receiving a replacement powerpack……sorry to say,
but Glitch was right in assuming the powerpack is ok…..and as far as I can tell it is !
here is what happens:
if I plug in the naked powerpack I measure about 6VAC across pin 1-2 and about
22VAC across pin 3-4.
the moment I connect the powerpack to the PS board its fuse blows – p2 and p3 are still disconnected.
so far I have not found a faulty component on that board nor a broken track that may be responsible for  the constant  blown fuse in the powerpack ???
every single component I tested was fine which begs the question ‘where from here’ ?
Obviously there is a problem I can not see nor measure.
ALF
