Reply To: Beosystem 2500 Cassete issues and Beolab 2500 issues
#10776
matador
  • Paris France
  • Topics Started 30
  • Total Posts 320
No. They are one or two little plastic clips you have to pinch to be able to slightly lift the PCB in order to push the belt inside. Then you have to fiddle a little to set the belt on the right path. and then find the right way to close all the mechanism with the pulley inside that path (the pulley Martin pointed as being on the metal bracket).
It’s as fun as Chinese puzzle but not impossible. There is a video on youtube about that, but I don’t know if it is helpful to that extend.
Also read my thread on this in the old forum: if your belt broke with the mechanism engaged there is an heart-splitting maneuver to do to make it work again.
Good luck.
