Home › Forums › General Discussion & Questions › Eclipse/Harmony/Theatre audio via Beolink › Reply To: Eclipse/Harmony/Theatre audio via Beolink
5 November 2022 at 16:05
#25714
Regarding the Bang & Olufsen support (I asked for support), audio streaming of the TV program from the Beovision Harmony to Beosounds does not work! In reality, it works but unfortunately with a time lag = echo.
True, if you playing something on the LG, f.e. the Music app of LG and link to other B&0 devices.
But NOT true if you stream directly, f.e. DLNA sources or TuneIN, to the B&o Harmony using the B&o app. Then the sound will be in sync. (if the time delay on al devices are the same, as supposed).
