Reply To: Eclipse/Harmony/Theatre audio via Beolink
#10753
Alsfeld
  • Topics Started 0
  • Total Posts 5
I own a Beovision Harmony and several Beosounds (1, 35, Core, M3).
Regarding the Bang & Olufsen support (I asked for support), audio streaming of the TV program from the Beovision Harmony to Beosounds does not work!
In reality, it works but unfortunately with a time lag = echo.
The echo is strong when you use the standard settings in settings -> beolink -> sound synchronization 1000 (wi-fi msec). It is much better when you go down to 100 msec. Unfortunately with decreasing msec the stability when steaming music getting worth. 100 is for me a good compromise working OK in my network.
  • This reply was modified 4 weeks, 1 day ago by Alsfeld.
