5 November 2022 at 10:05
#25722
You basicly want to ‘swap’ both.
This can only be done if you reassign one of the inputs to something different (in order to free up the button on the remote).
After that you can change the other and (because that button now has been freed), you can give the first one the ‘name’ that you want.
Short….if you want to use the Beo4-button – that you already use – for another input, you will have to free the input of its assignment before you can go on.
